Looking for a users manual for my 2008 20I multi function gauges. It is round gauges and with this part number on the back 6z160271. Two gauges with a mode and set button on each.
Ok, maybe this will get a response. When I purchased the boat it had Lorance at the bow and stern. I had both moved and installed hummingbird, now the trip and speed do not function. Did this have something to do with switch?
The Outboard owners manual has the operating instructions in it, go to www.yamaha-motor.com to see manual.
Probably need to clean the speedo pickup tube on front edge of lower unit.
