Good Afternoon,
First off, new to the forum, and I have found some useful info. I am looking for assistance on installing a hour meter. I have a 2010 Tidewater with a Yamaha F150 on it.
Here are the specs; http://www.tidewaterboats.net/bullet...cc-f150txr.pdf
I purchased a Faria hour meter and installed it in the gauge panel;
http://faria-instruments.com/cgi-bin...hite&id=MH0056
I was curious if there is a place I am able to hook this up on the current wiring harnesses from the boat/Yamaha or do I actually need to splice into another wire that is powered by the ignition? If there isn't a place to connect on the wiring harness can I hook into the other gauges?
Thank you for any help,
Brian
Brian
