Trim and tach gauge not reading properly?
  • Trim and tach gauge not reading properly?
    About 2 months ago my trim gauge stopped reading properly(it would not read all the way down, it would only go about 3 bars from the bottom,but the physical level of the actual trim was working fine. On my last trip out, the Rpms started reading funny. When I would engage the motor and trim down at the same time , the rpm will read zero. If I just engage the motor or even when I trim up, the Rpms read properly. Any suggestions.
    Check all wiring between key switch and gauges and between gauges and engine, check all ground connections on engine and gauges. Check battery cables and connections.
