New 4 stroke 70hp prop
  • New 4 stroke 70hp prop
    I bought a new xpress 18ss with a 70 4 stroke, i think the prop is too big, it has a 15 p power tech. the dealer said it would be ok manufactor said should have a 13p. When it is loaded it will not reach max rpms will on reach 4500.
    it seems to lug down when loaded. Would the 13p make a difference.
    its either broke or way way way way over propped.
    what year is it?
      i bought it a few weeks ago it is a 2011
        operating range is something like 5300-6300 RPM.
        its fuel injected.
        its either broke or way way way over propped.
        I will look when I get to wook if there is a test wheel for the F70.
        but you have an issue.
          I recieved and email form xpress they said that i should have a 13p on it. My dealer said he wold order one for me but it might be a week or more before it comes in.
            typically each inch of pitch change will give about 250 RPM up or down.
            you need about 1800 RPM change.
            I dont think its a prop issue
            you need to have it run up on a test wheel, I dont have the test wheel part number here at the house but there is one.
            seperates hull/prop issues from engine issues.
              Ok i will talk to my dealer.
                Dealer sent me a new power tech prop 13p installed it Friday now the max rpms is 5900. All seems to be good now.
