Thanks again Rodbolt - i'm sure the oil level isn't low, so the SWB is open. I will check for bad connections, broken wire or the switch in the remote tank is bad.
Oil transfer from reservoir to engine tank
Rodbolt,
So I check wiring for visual signs of damage, corrosion in the connections and didn't find any. I have a multitester (but it doesn't have a continuity testing ability). I believe you indicated that the Brown wire could be causing the issue and I see where that comes into the remote tank connector. Can I check with the OHM test on the multitester or do I need to borrow my friend's multitester that has the continuity testing ability?
Also, if you could walk me through the basics I would appreciate it?
Stick
Hi folks. I just signed up on the forum to gleen some much needed advice on 1998 130 saltwater series engine.
I searched the forum and this thread seems to be as close as I can get to finding instructions for hooking up one of those 2.8 gal. oil tank kits (p/n 6YR-W0035-94-00).
I recently purchased a kit and it didn't include any instruction sheet or manual. Would anybody on here be able to post a link to such a sheet or direct me to where I could download it? It would be greatly appreciated.... Thx in advance
Jeff
Â
