the power trim motor works fine in the down position. When in the up position the motor seam to bind down and barely turn. Sounds somewhat like an air lock. I can toggel the switch and it will slightly move up each time. What is the likely cause if the system works only in one direction? Why is it bogging down, is there a value restrickion, or malfunction. The trim motor is only 4 months old.
