My Tach is maxed out
  • My Tach is maxed out
    Good Morning. I have a 1990 Yamaha 50Hp 2 Stroke. This Weekend I developed a problem with the tach maxing @ 7000 as soon as the engine is started. engine is just idling but tac is pegged. could someone point me in the right direction to the source of my trouble. Thanks
    This may give you some help
    http://faria-instruments.com/site_ma...achometers.pdf
      Sometimes tach get little quirky
      Behind tach there usually is adjustments. Just going through the ranges clicking helps them work. Try go back to setting that worked before, no problem running.
        Thanks to all, I will check asap
