Yamaha tachometer w/rigging kit 6YR-W0035-E1-00
  • Yamaha tachometer w/rigging kit 6YR-W0035-E1-00
    I recently purchased this tach with a new 09 F150. I installed and cant seem to get the oil and temp gauge running. I see there is a 4 prong plug that I cant find where it goes... if it goes anywhere. I could use some help on the engine side of this. is there an adaptor or ??
    Alandryfp@comcast.net
    think you need the e2 gauge after '04
    QUOTE:
    We have new ones available but no used ones,
    6YR-W0035-E1-00 Multifunction Tach kit, 1994-2004
    __________________
      Oh great thanks, so dies the wire harness that would come with the E1 work with the E2 ? or is there an adaptor?
        I am reading everywhere that the E1 is for 2005+ are you sure about this?
          6YR-W0035-E2-00 Yamaha Digital Multi-Function Outboard Tachometer 2005+
          6Y5-83570-S5-00 Yamaha Digital Multi-Function Speedometer, 3-3/8 hole size
          6Y5-W0088-54-00 Yamaha Digital Fuel Management Gauge, Single Engine, 3-3/8 hole size
          6Y5-W0088-65-00 Yamaha Digital Fuel Management Gauge, Dual Engine
          MAR-DEPTH-FN-DR Yamaha Digital Depth Finder, 2-1/8 gauge hole, white & black
          6Y5-W0088-80-00 Yamaha Digital Multifunction Speedo - Fuel Mgmt Gauge Kit, Dual Engine
          6Y5-W0088-70-00 Yamaha Digital Multifunction Speedo - Fuel Mgmt Gauge Kit, Single Engine
          6YR-W0035-E1-00 Yamaha Digital Multi-Function Outboard Tachometer 2004 or older
          not sure if you can use an adapter
