First posting here.
Recently re-powered my boat with a 2006 Yamaha 90 4-stroke, 235 hours.
Motor runs perfect, but there is a blinking symbol in the tach that indicates water in the fuel.
Fuel in the tank is fresh, I have a 10 micron filter that is virtually new too. The small filter on the engine has been cleaned out.
I can't see that the motor even has a sending unit for water in the fuel. If it had one, where would it be
Could it be that something is connected that should not be? Could there be some kind of defect or incompatibility with the Yamaha tach?
I also have a problem with the trim indicator in the gauge no working properly. The plactic cam on the tilt tube is broken, which I understand is quite normal. I bought a new cam, have not installed it yet, however, when I move the sending unit manually, it seems to make no difference - could these two issues be related in any way
Really appreciate any feedback!
