1998 90 hp
  • 1998 90 hp
    i replaced fuel pump,spark plugs and cleaned carbs and it still busts up when i try to throttle up.
    anybody had this problem before,or any ideas how to fix:
    does your buzzer work correctly ?
    how long has it done this ?
    what gauges do you have ?
    changed filters recently?
    try feathering choke see if it helps motor run
      changed fuel filter, overheat buzzer works correctly,oil buzzer works,only have fuel gauge and speedometer.its on a 97 skeeter,how can i check coils ,i put spark checker between plug and coil and they seem to be firing.
        if it "seems" to have spark you dont need to check coils
        how long has it done this?
        fresh gas?
        new water separator ?
        compression check ?
        i would lean towards a fuel supply issue, again if you feather choke while running and it helps youll need to go thru carbs again
          it doesnt have water seperator ran fine last year,winterized it and started acting up when we got it out to get ready for this year.we are using fresh gas in a seperate container.it doesnt have chok e it has thermal assist.
