I have a 2005 Yamaha 40HP 4 stroke engine hooked up to a FARIA CORP. Tachometer model TC9026A and it does not work. Is this tachometer compatible with this engine? Engine P/N 67C F40BET L 1006083.
I used this gauge on an old 2 stroke and was working fine. Hooked up to the 4 stroke, it will not work no matter what pole switch position I select. I have the signal wire connected to the green wire at the control box which goes to the grey wire on the voltage rectifier/regulator. According to the Yamaha wiring diagram, this is correct. Any help with this would be greatly appreciated.
