Hi All, just got my imported Pioneer Cape Island 186 with Yammie F150. I put my outboard muffs on to run it and had no water come out my telltail after a minute running. Prussure good at the muffs, and water steams coming out other galleries in lower leg. Removed alternate flushing port on left side of moter and with motor running was good water pressure pumping out of connection. Lower leg impellor = good .
Thought there might be apossiable blockage at tell tail when shipped. Placed 200lb monofiliment line up but felt all good until it hit the cooler assembly(fuel/water brass block) and didnt go any further.
Traced water line back around to upper exhaust plate and tried to remove the water line out only to snap the brass fitting(Hose nipple still in hose when it came off!!!) (can i get the hose fitting seperate as the parts breakdown dosnt list a seperate item and need whole exhaust cover)Tried running with hose off to see if there was a blockage from exhaust plate to cooler assembly after a minute still no water??
My next call was to pull out thermostat? Any other suggestions?
Cheers
Aaron
Cheers
Aaron
