I have a 2009 F 40 LEHA that I suspect has an airkeak in to the fuel system because my filter/water dectector is operating at 3/4 full. The motor runs ok most of the time, but will cut out at both idle and speed at others. Seems like a fuel starvation issue when it happens. Any advice out there is welcome.
F 40 airleak?
only one service tech on maui
I had a visit with the service tech today. He told me the filter cup should be full and the service bullitens are confidential to dealer ony. He also admitted he doesn't work on many Yamahas.
My confidence with this company is near zero. What are my other options?
F40 LEHA 6GB L 1000324 G 10/08
only tech listed on Yamaha website
Roger that! That's why none of my motors have ever been in that shop. The only other dealers listed are on Oahu and the Big island of Hawaii.
Can you, will you or anyone else out there run my numbers?
I've run Yamaha four stroke 40hp commercially since 2001 and have the carbed models pretty wired. I have a service manual in hand and a fuel pressere gauge coming in the mail for my EFI model.
look at bulliten # o2010-0007.
your F40 is covered, affected seriel number range for the F40leha is 6BGL-1000038-1012919.
can be identified two ways.
1 is the original pump outlet cover was black, the updated one is brown. or two a blue paint dot on the lower front corner of the VST.
why buy it?
make a deal.
its not a difficult job its just a pain in the rear job.
takes about an hour.
may take you slightly longer.
I can do things a bit faster than most the yamaha tech reps.
I challenge them occasionally but only once got an acceptance, beat him by 4 hours on a pair of z200 powerhead replacements. he did one, I did the other.
however I have done this type of work over 35 years.
Ford dealers,porsche,mazda,volkswagon, mercury marine,mariner,honda,tohatsu,suzuki,yamaha,go devil,chevrolet, mercruiser,volvo penta,Force,chysler marine,took a few years off programming and setting up CNC lathes and Mills for Gearhart-Owens (GOEX) explosives then about 6 years in the United States Navy's advanced electronics thingy.
and some part time jobs learning how to bore blocks,grind cranks and such.
I actually should be a millionaire but I just enjoy what I do so I bought a house on the water and I am living the american dream.
somebody help me .
I just talked with the tech and he looked up the bulliten while I waited. He says he'll call back after researching a little more.
Rodbolt17, Thank you kindly for all you help. Your life experience, knowledge, familiarity and understanding of these systems is greatly appriciated.
Respectfully, Mark
