1996 50EJRU 50HPJet
  • 1996 50EJRU 50HPJet
    My liner is worn down...Do I also have to replace the Impeller?
    Is this a difficult procedure?
    Liners are cheap compared to the impeller, replace it first and adjust your shims on the impeller to see where you're at. When the time comes, I recommend their 6 1/8 stainless steel impeller, I've used mine for almost 2 years and still have not had to dress the leading edges.
      Thanks...I've adjusted the shims before with no problem and the liner looks simple...Take out a couple bolts and maybe a love tap or will it require a press?
        A tap should do it unless you operate in saltwater, then you will require two taps.
          Stainless steel impeller
          The liner was easy to find, but if I need to locate a stainless steel impeller do you have a sugestion of where to shop? I've looked at a couple sites with no luck...By the way, not much saltwater in Arkansas...Thanks again!
            I purchased mine direct from Outboard Jets, I believe Wooldridge also makes stainless for different motors.
