Hi, my yam f80 (Carb'd) is making a popping noise throught the air filter above idle? i have adjusted the throttle sensor switch? what is the cure ?? reguards Graham
yam f80
mixture screw
how many turns would i turn the mixture screw out?? its currently at 2 3/4 turns out the popping is not constant ,so i think the inlet valve could be ok ??? Graham would you recommend petrol for the leak down test, and at tdc on all cylinder individually, many thanks for your invaluble advise Graham
