Please read entire story before offering advise.
I bought a used 2002 prokat 22 ft with 2006 twin Yamaha F115TXR in March of this year. Here is the story.
Original owner had a insurance claim on the boat in December of 2009 and his previous motors were replaced by insurance with these 2006 F115. They were new leftover engines. (warranty puched 12/09, I have the warranty cards.) When the motors were installed $5 in gas was put in each gas tank and motors were water tested. Fuel was not drained and boat set from 12/09 until 03/11 when I purchased it. That is the story on the boat now here is mine.
One motor runs 100% great so lets focus on the other. I replaced both batteries, oil, oil filters. The one motor initially would spit and sputter at anything over 1500 rpms. ZReplaced exterior 10 micron fuel water seperators. After that the engine would run up to 4500 prm's for about 1 minute then would cut back to 3800 rpm's. If you stay under 3800 rpm's for a few seconds you can get back up to 4500 rpm's for a minute and it would drop to 3800 again.
Took boat to authorised Yamaha dealer and had VST tank and filter cleaned (filter was not replaced, I should have ask.) Still same symtoms and was told I needed 2 injectors. Not one to skimp I went ahead and replaced a 4 injectors and small fuel filter under the engine cowling. Now the boat will run up to 5500 rpm's for about 3 minutes and the cut back to about 4200 rpm's. Once again if you stay under 4200 rpm's for a minute or 2 you can get back up to 5500 prm's for 2 or 3 minutes before it falls in RPM's again.
Obviously I am making progress and am almost there. What should be my next step. The only filter that has not been replaced is the inline right before the VST tank.
