i have an issue with low pressure pump, boat was running out of fuel checked low pressure pump was not running so i replaced it. ran fine for about 6 hours second time out seems to have went out again. i have 12v to the pump on red wire to clean engine ground with key on, i bench tested pump and it clicks but does not make a running sound and does not pump fuel, just like the old one. first question would be , plug unhooked with a volt meter hooked up between the red and blue wires going into pump should i get 12v with key on, because i get 0v all the time. i do get 12v on the red wire with key on and other meter lead going to engine ground. could this be the driver going bad ? next can the driver cause the pump to go out ? and if that is a regular 12v pump if you put it on the bench and hook black to ground and red to hot the pump should run , correct ?
any help would be great
