2006 F115 - new LP fuel pump needed???
  • 2006 F115 - new LP fuel pump needed???
    I have been experiencing occassional stalling/hesitation on takeoff and occassional surging at higher rpm under load.
    I pulled the low pressure fuel pump. The manual said to perform 3 tests.
    1) Apply 7.1 psi to pump intake; I applied 10 psi and it held 10 psi for a minute.
    2) Apply 4.3 psi (8.75 in Hg) negative pressure (vacuum) to intake; I applied 10 inHg and it fell to 7 inHg in a minute
    3) Apply 7.1.psi to output side; I applied 10 psi and it fell to 6 psi in a minute and continued to fall
    I also pumped the ball while the pump was off the engine but with the fuel lines still hooked up, the ball got hard and I saw no visible sign of gas escaping.
    Based on these results, should I get another whole pump? Rebuild this one? If I rebuild this one, which parts are needed for the rebuild. I believe this could explain the bogging issue. Any help is appreciated.
    based on your tests and my experience, your lp pump is most likly fine.
    your VST filter and injector filters are most likly clogged.
