2001 90 HP Yahm 2 stroke oil leak
  • 2001 90 HP Yahm 2 stroke oil leak
    Hello,
    I have a 2001 90 TLRZ and it's leaking 2 stroke oil. I think I have traced it back to the reservoir on the lower side where the oils gets sucked into the engine. I am unsure whether the pump needs to be replaced or the reservoir itself? the leak is from the top where the assembly goes in almost like the seal has worn out on the pump, Thanks for your help.
    If you are speaking of the tank mounted on the motor, I believe there is a level switch in that tank but not a pump.
      yes that is the tank I am speaking of. thank you I will probably just assume that the tank is fine , and the part that needs to be replaced is the level switch.
