Hi, Can someone please email the installation instructions or the link if they know where to find it. I have installed the system, however I think the sender may be faulty. It seems to restrict the fuel to the motor after about 5 minutes of running (which is when the internal engine filter bulb runs out of fuel). It is installed after the filter and before the primer bulb, but the primer cannot suck the fuel up to prime the motor with the sender installed. When I take the sender out it works fine.
I was able to blow through the unit, and it looks clean and doesn't seem to have any obstructions. I will try and test it with power on again, but I would think that these things should fail safe and let fuel through in any case. Has anyone experience any fuel restrictions after installing this?
Any suggestions?
My email address is hawins013@bigpond.com
Any suggestions?
