Took the boat out for a quick run today just to blow out the cobbwebs. Temp guage went up to about the 75% mark when running wide open. Running at 1/2 to 3/4 thottle the indicator would remain in the middle of the temp display. Returned to normal after cutting the throttle back to about 25% and ran for a few minutes. Is this normal? Should the engine run a little hotter when running so fast? Just had the lower unit repaired with a new Prop shaft and seals, and also had the impeller changed with housing. Last year when *****ing, 5mph or so, the engine would over heat and I would get an alarm and had to shut down for 15 min or so. I hope the impeller change will take the overheating issue at *****ing speed away. I wonder if I need to change the Temp sensor or somthing else.
Yamaha F250TUR overheating?
nothing is "standard"
could have been rigged with command link,digital 6Y5, or analog.
then there is aftermarket.
choice is up to the hull manufacturer or the guy that rigged it.
with comand link its normal to see it at about 75%.
if you get yor command link book out you can actually set it to see the actual temp.
up and running above 4000 RPM 180*F or so is about normal.
*****ing I have seen as low as 90*F.
its a lot of aluminimum heat sink your dealing with and unlike a car it uses raw water for cooling.
ÂÂ
