I have a Twin F225 TXRC Yamaha outboards. At low idle they sometimes will conk out. I will then pump the ball and fill it with gas and then it start back up. This never happens at cruising speed, just at low idle or *****ing speed. And it is not consistent either..sometimes it happens and sometimes it doesn't. I am not sure what I should look at. Is it the low pressure fuel pump or some other pump or valve. Can any of you experts guide me in the right direction?
BTW, I have replaced all fuel lines, Water Separator filter and the fuel filter inside the engine, and the pump balls.
