prop for t-50 four stroke
  • prop for t-50 four stroke
    bought an 09 t-50 4-stroke. a dealer sold me a solas 11 x15 aluminum prop. took forever to plane and turned 4200 wot. looking around i think i need larger diameter ~13 1/4 " Ideas??
    boat is a 16' v-bottom flats skiff
    check here for a rig like or close to yours and see what prop they used and how it performed.
    You may have a problem with the motor or the set up if it will not turn high enough RPMs if you have proper prop size.
    Performance Bulletin Home
      prop for a t 50
      call yammi customer service, he has the same boat and can give you alot of insite for your question. you won;t be sorry.
      mudjon09
        prop for a t 50
        i have a t 25 2004,i called the yammi cust serv rep, he asked me to try a 10 1/2 x13 to replace a pontoon prop that was a 12 1/4 x 9. the new prop gave me 7 mph more than the one that was on it,(a new one), when i bought the motor used.there was several options i found by looking at their prop listing on line.these i think are foe a standard motor (not a potoon prop). you do realize that the motor you have has a different ratio in the lower unit than standard which changes you speed output some.i was running 6000 rpm at wot, changed the prop, went down to 5600 and 7 more mph.
        my t25 has a 50 hp mid and lower section on it ,as thats the way yammi builds them to give them more strength as i was informed.
        a new prop from my yammi dealer costs me about 130 bucks(aluminum).
        the serv rep i skoke to had a 50 on a 16 ft alumn skiff and had also put 3/8 gas line on it too as to not starve it ,i;ve found it does help.
        mudjon09
          I had solas on boat and lost performance big time even droping pitch
          My better judgement say's dont get one. Im shopping for 15pitch right now
