Help with my 1996 40 hp yamaha 2 stroke
  • Help with my 1996 40 hp yamaha 2 stroke
    I have a 1996 40hp yamaha 2 stroke. Runs beautifully
    Just changed
    Plugs
    Lower unit oil
    Fuel filter
    Drained the carbs and flushed them out through drain screw.
    What else should I do to complete my maintenance procedure.
    Been about a year since last service. And sat for 5 months this year. Since that 5 months I've taken the boat out every weekend and it seems to be running beautifully. Have a full can of sentry and seafoam sitting here. How shall I use it.
    Also is using 93 octane plus 50:1 mixter of 2m yamalube a good mix?
    Neutral idle is ok but when I have it in forward gear and at idle speed I think it has a rough forward idle. It ****s a little side to side but nothing major
    ditch the 93 octane, waste of money at best.
    keep the 50/1 yamalube mix.
    that engine was designed for us of 87 octane.
    no comment on additives.
      How long since check/replace water pump impellar? Remove prop, check for fishing line wrapped around shaft/under prop shaft oil seal, grease prop shaft splines. Grease all zerk fittings on motor swivel and tilt. Good Luck!
        check fuel pump pressure/vacuum, anodes, thermostat, grease everything
        have you looked at what Yamaha recommends as for maintenance?
        http://www.yamahaoutboardparts.com/f...s-th11558.html
          I have not replaced impeller since last service a year ago. It sat for 5 months so really hasn't had alot of use on the impeller since last change out. I have taken the prop off and inspected and re greased all proper areas.
          I have a can of seafoam and sentry. I want to use the seafoam to clean cylinders and well as carbs, how should I go about this.
