I have been told to clean the bowls on my carbs due to a little rough running up to 2000 rpms, after 2000 rpm it smooths out. Do I have to remove the whole carb assembly (all 3 carbs) or is there a drain plug that will drain the carbs individually without taking them off of the engine. And if so do you think that it will cure my rough running problem? I am pretty sure that the carbs have some debris in them because when I trim way up it runs better than trimmed all the way down! (up to 2000 rpm) Thanks in advance for advise !!
how to drain carbs on 2007 70 hp yamaha
