Need to clarify shaft length from serial number
  • Need to clarify shaft length from serial number
    Greetings,
    I'm about to order a new lower unit for a 1994 200HP 200 TXRS and am not 100% certain what shaft length I need, Long Shaft or Ultra Long Shaft.
    The serial number off the motor is 6G6 UL 766533.
    Am I correct is assuming that the "UL" in the serial number designates Ultra Long shaft?
    Thanks for your help,
    Old Keyser
    the X indicates it is a 25" xtra long shaft
      Thanks for the response, however, when I look at the choices of lower units at boats.net here:
      Yamaha Outboard Parts 1994 200TXRS LOWER CASING DRIVE 1 (150 - 175 - 200) Diagram
      there are two choices described as LONG or ULTRA LONG, and specific indication of the actual length of the shaft is given. Am I missing something?
