hi i have a 98 130hp yamaha just wondering if any1 knows the correct float levels for the carbs and how to measure them any info would be great thnx
float levels
I think the Yamaha manual specifies 0.630" +/-0.020" (16.0 +/-0.5 mm). Floats installed, housing upside down measured from top of float opposite to pivot side down to housing wall with gasket removed.
Makes a huge difference to engine handling if you ask me, mine was set too low from last service and struggled to start - particularly if motor was not trimmed all the way down. When I checked mine they were set at 19 mm, since the correction starts fine!
Hope this helps!
Â
