I ordered a new Power Tech 17p prop to replace my current Tempest 23p, I removed the Tempest and installed the Power Tech using the same brass spacers that were on the Tempest and there was IMO too much slop in the new prop. Where/ or do I need to get new brass spacers?
Pro-V and Power Tech Prop?
Performance Bulletin Home
Here is a site that shows how a lot of different boats were set up, you can always check to see if they have a rig like yours and what prop they used, the RPMs and other info they got.
Like I said check with the place you got the prop and make sure the prop is for your motor and what all is needed. some props had different hubs
