How many lbs required to tightened up prop
  • How many lbs required to tightened up prop
    What's going on fellas. I was told that you need certain amount of pounds to tightened up the prop. I have a 2002 yamaha 150 V6 2 stroke. Any advice will be appreciated..
    Mike
    Mike
    For my 2005 F150, the torque spec is 38.4 ft/lb. I believe your lower unit might be the same. If you have to go a little more to line up for the cotter pin, no problem.
      it also depends on who made the prop and the type of prop hub being used.
        I always use just "good and darn tight", then a bit more if required to line up the cotter pine holes. No need to put the "gorilla" torque on it, after all it's just the prop on the shaft! Good Luck
          some after market props with replacable hubs require 55 ft lbs.
          thats why I wont answer a half question.
          dunno what you have and you aint a sayin so we be quiet.
