Anyone know what Flagship marine does to rebuild these pumps, I have taken my cover off and removed the screens and still runs the same, starts bogging down bad above 1900rpm, new plugs fouled real quick just water testing engine.
Changed gas in tank, changed water seperator and have been testing with remote tank.
changed vst filter, bowl filter, medium pressure filter, have 50 psi at all times.
So looking at many forums I seen many threads on these pumps, so I took my cover off and removed screens, put back together and water tested no improvement. Will start and idle ok but bogg when throttle up to 1900rpm.
So my dilema, pull pump and send out, or buy new since I have 950hrs on motor. Also should I pull injectors at same time and send out with pump.
I did try to back probe pump sensor but no matter what combination on the 3 pins I either got 5V or 4.5 volts, from prevois threads I should get between 2.8and 3.2 volts, wil this sensor cause the problem?
