703 con*****er questions
  • 703 con*****er questions
    I just purchased 703 con*****er and I thought it would have overheat alarm in control box. No buzzer was in there.
    I am buying a 1996 manufactured Yamaha saltwater series 2 150 engine. Do I need an overheat alarm , and should the new 703 unit have come with buzzer?
    model 703-48207-18-10 Deluxe Yamaha Side Mount Control
    engine S150TXRU thanks mk
    Yes I would suggest to install a buzzer or get the new control box.
      buzzer
      when I bought engine, prior owner had buzzer from the 2 key ignition switch. It had pink and yellow wire. Can I install this in my new 703 con*****er?
        if your 703 has a 10 pin main harness then yes you can.
        if it does not have a 10 pin harness it wont work anyway.
