I have a 1990 - 9.9 hp SD. It is dumping gas into the water, hard to start and will not come up to full RPM unless I remove the fuel line.
I have replaced the needle float valve assembly. Set the float to insure that the float is horizontal to base of carb when needle is seated.
What is the initial setting for the air mixing screw from a full clockwise position?
I wanted to try new high and low speed jets, but there are two different jets for each. How do I know which to purchase?
