what is involved and what gauges do I have to change in the dash I do believe its a lf250 tr with digital gauges 2007.
changing johnson 225 oceanpro to f 250 four stroke
Tags: None
The yamaha does have digital gauges not controls its a 2007 f250txrLast edited by macmachine; 02-21-2011, 07:58 PM.
you will need a control box, the ign harness and the oil/trim harness and 33 series control cables.
box will depend on if your using flush mount,side mount or binnicale.
you can use the 6y5 digital or the 6y8 command link guages.
if using the 6y8 you wont need the trim/oil harness but you will need the main harness and hub and pigtail harness.
Â
