on a 2009 115 yammie, how is the best way? I know you can suck it out but is there a drain somewhere? If you suck it out what kind of pump do you use?
changing engine oil
on my 4-stroke there is a drain bolt located on the back of the middle housing, it is a hole. here is a great link for you. YouTube - Performing an annual service (oil change) on Yamaha outboard - Sunrise Marine
