I Was told when i bought my T25 2004 4 strker (used)that it had a 50 hp mid and lower unit on it ?
is this correct?
if so is the prop shaft a 50 or a 25 rated shaft?is this spline count the same ?
only ,of coarse ,if this is a 50 hp unit ...can i put a 50 hp prop onit?
i now have a different prop than what came with it ,as i could only get 20 mph @ 6200 rpm ,and i now have a standard type prop from yammi, and i can reach 27 mph at about 5700-5800 rpm.
i am at this time looking to change to a tiller setup on my boat ,also hoping to attain more speed because of less weight and less problems caused by more mechanics to give you grief.
mudjon09
is this correct?
mudjon09
