Fuel tank indication.
  • Fuel tank indication.
    Hi
    I have bought a new Yamaha F150 2010 model. I want to install a fixed tank. The tank will be either 330 mm or 400mm deep. What yamaha sender do i need to interface with the yamaha bus and the round guages?
    Thank you.
    Martin.
    depends on the fuel sender, the yamaha one, the european one or the US 255 to 35 Ohm one.
    the guage can be calibrated for any of the three.
    depends on the sender resistance from full to empty being used.
      Thank you rod bolt do you know the part numbers say for the yamaha one so I can order it. Do you know what different depths they do.
      Regards.
