9.9 t9.9exhy drive shaft
  • 9.9 t9.9exhy drive shaft
    I am trying to replace the drive shaft on my 4stroke 9.9. can someone point me to the right direction on how to do this?
    Do i have to remove the propeller shaft?
    prop shaft comes out, the undo the pinion nut then remove the drive shaft then remove the drive shaft bushing housing.
    otherwise you break the bushing housing.
