I have a 1994 75 h.p 2 stroke. Has been sitting a few weeks.Cant get it to start. Any help out there?
C75tlrt 1994
94 Yamaha 75 h.p.
Thanks for your responses. It wasnt getting fuel to the carbs. I almost think it may be the end of the line that plugs into the motor. Finally got her fired up and running. When you are putting up for the fall and winter do you recommend running all the fuel out of the carbs?
You are probably better off stabilizing the fuel and make sure it is run long enough to get it completely through the system and then drain the fuel bowls if you put it up for over 6 weeks, but that is only my opinion. It will evaporate and leave residue in the lines and pump still, but that is better than leaving a small amount in the carb bowls as you can not run it all out of the bowls before it dies.
ÂÂ
