Hi everyone,took my Phantom 20 out yesterday to try and nail down why it broke down in october.I thought it was electrical but yesterday I discovered that the problem disappears once the motor is running quite hard,if I can get the boat up on the plane over 2500rpm approx it goes great.idling is very erratic and keeps stalling when you put it in gear.I have checked the carbs(clean as the day they were made),fuel pumps,tank,filter is new,fuel is fresh,primer bulb pumps up hard.
Could this possibly be a reed valve problem?
Also when idling in gear if you flick the choke switch before it stalls the motor
instantly clears for a few seconds then starts to fail again.
Looking forward to some good ideas.
