Is there a way to connect a Lowrance ep 65r fluid level sensor to my oil tank ? Is there an oil sender on the tank
sx 200 txra
anything is possible.
while there is no real level sender in the tank there is a level switch.
when oil level gets low it opens and your tach display goes from green to yellow or from right bar/arrow to center bar/arrow.
way faster and easier method?
fill the remote before each trip and watch the tach.
test the alarm system once a month,just like the maint schedue says.
its quick easy takes 5-10 minutes and can accomplish 3 tests at the same time.
