i have a 2006 yamaha F150TXR that powers an 18 ft grady white sporstman. The motor will get the vessel up on plane then loses power after a few minutes. I did have an issues with water in the fuel but drained the tank and changed the filter and fuel water separator as well as the plugs. Any ideas on what could still be causing this issue.
losing power
This is the F150 VST. As said before the manifold must be unbolted, but complete removal is not necessary. The plastic intake tubes must be removed. Care is necessary to avoid losing parts. It is not a difficult process, but is somewhat complicated. Some of the screws holding the VST cover on will come out stubbornly. Proceed with care. The filters (shown on the lower right edge of the bench) are not cheap. If you have a digital camera, take pictures as you go. A good number of fuel connections to hook up when done and you'll want a record of what goes where.Attached Files
Originally posted by gwyami150 View PostThanks, I checked the VST and cleaned all the filters and injector screens and boat ran fine today other than running a little hot. I may have to change the water pump impeller i guess? Any help on how to do that would be appreciated
You really need to make sure you cleaned fuel system all well enough as a lean running motor can cause heat as well as not enough water flow or blocked water passages
