Tachometer low reading
  • Tachometer low reading
    Hi everyone,
    Recently I installed four stroke engine tachometer on my 2 stroke engine.
    Maximum RPM I reached was 2300.
    I think that something is abnormal.
    Please advice why tachometer is shows such low RMP
    Thank you
    try setting the tach for the correct alternator pole setting.
    typically most 50 hp and above 4 stroke yamahas set at 12 pole.
      Thank you very much. I,ll try
        tach setting
        How did this work for you? If successfull, what did you change? I think I have the same problem on my 96" 60 hp.
