Hello all,
I have twin four stroke 250's on my boat. They are 2008's. Ever since they were new, when it is cold(below 40 degrees or so), they will idle low(3 to 4 hundred rpm's) and a little rough for a few seconds before winding up and idling at their warm up speed(around 900 rpms). Once they rev up, they run perfect. Both engines do it, and by and large only do so when it is cold. I am assuming the cold start map doesn't account for these very cold conditions.
Today, I noticed that one of the engines didn't want to rev up. It slowly gained speed until it was idling at 800 rpm's(took about 20 seconds), but it just wasn't running right. I gave it a moment, and as it was still not running quite right, I shut it down and re started it. Once re started, it ran perfect. My question is...once I re started it, I went to the back of the boat and I noticed a fuel slick around the back of the engine. I was a little concerned, but after thinking about it, I am thinking the engine was running rich(cause of rough idle) and when it re started, it passed some of the unburned fuel out in the exhaust. Would this make sense? I ran the boat right after this, and it ran perfect from idle to WOT of 6100 rpms. Fuel burn was normal.
Thanks for your help.
