I have a Yamaha F115TXRB 4 stroke outboard. This is 2003 year.
The motor will not idle down after startup. Runs at 1200RPM. I have checked all sensors and the Idle air control by swapping with a friends F115. All components check out fine. The problem seems to be with the ECU itself. I have ohmed out all the wires at the ICM to ECU harness and all is OK. The ECU is not telling the Idle control motor to adjust. I was able to get it to slow down by connecting the ICM to the harness on my friends motor while it was running. The motor adjusted closed and I then reinstalled in my motor in that closed position which slowed it down. It will not speed up at restart. You can take the idle air hose off the intake at the ICM and slow the idle down by partially closing the air flow to the ICM.
What happens inside the ECU to cause this lack of responce? Is everything in there solid state? Is there software that can be reloaded?
$1,000.00 is alot to have to sink into this for bad idle speed issue.
Thanks, Marty
I am in the process of trying to find willing person to swap like ECU to confirm my diagnosis.
Thanks, Marty
