On the Yami 225 how do you check your trim fluid levels. Is there a simple way or is it best for a dealer to handle? I only see 1 cap and is mid level and would seem as though fluid would pour out if opened? If I check it do i need to bleed the lines after?
225 Trim Fluid Levels
Toads,
On my C115 Yammie, to check fluid level, tilt motor all the way up with power t/t, drop down the locking lever for safety, and then remove filler cap on t/t reservoir - add fluid till it reaches the bottom of the filler neck. Your Yammie 225 should be the same.
Good luck,
Ken K
ÂÂÂÂ
