T9.9 Carb thermal valve
  • T9.9 Carb thermal valve
    After rebuilding my 2004 T9.9 power head I have a hard starting problem. If I put my finger over carb intake it starts fine and runs perfect. When the motor is warm no problem starting.
    Could someone please tell me how to trouble shoot the thermal electric valve circuit, ie: resistance and voltage?
    Thank you for any help
    look in your service manual.
    it gives specs for resistance and pin dimensions both cold and hot.
    its power comes from the lighting coil but you can test it with 12V and jumper leads.
    a quick test is to remove it,measure the pin, attach it to 12V and wait 3 min and remeasure the pin.
      Thank you for the info. That is exactly what I should be checking.
