I am a novice with outboards. My 89 70hp has alarm sounding, pisser has only steam coming out whilst under idle, hard throttle has water coming out like fire hose -but hot, and the problem wont let all cylinders fire (I assume is safety measure). Impella is sound. I dont know where my thermostat is, any suggestions please.
Yamaha 70hp 2 stroke '89
Look here. I assume this is your model no.
Yamaha Outboard Parts 1989 70ETLF CYLINDER CRANKCASE Diagram
no 30 on diagram
When was the last time the water pump was replaced?
Sounds like you need a pump kit and make sure the housing is not a problem while you are in there.
The water pump should be pushing water out the indicator hard even at idle, at least the newer ones do.
Have checked water pump housing and impella - all seem sound. My question now is really A)Does this model of Yamaha have a "de-rating" system - where if an imperfection exists somewhere, the motor cuts down to running less cylinders as a safety measure and/or B) Does the alarm itself have the ability to trigger any such "de-rating"??
Â
