I just went out to my boat and started my 1996 80hp Yamaha outboard. Ran a little rough since it hadn't been cranked for 6 months or so but that is normal. After a few minutes of running rough, the throttle started increasing so I shutt the engine off at the switch. Checked the linkage to the three carburetors and all appeared to be normal. Restarted the engine and again, on its own, the throttle increased until the engine was running near red line. I turned the ignition key off and pulled the kill switch but it continued to run at full throttle. I then pulled the gas and after about what seemed to be an eternity, the engine finally ran out of fuel and died. I have no idea what-so-ever what could be the issue. Pulled the carburetor air filter and things looked normal. Check the linkages again and everything looked like they were working normally.
Can anyone offer a suggestion as to what the issue can be? I just retired and was trying to get my boat running to do a little fishing, but looks like that is going to be delayed somewhat. Thanks in advance.
