Hi guys I have a question about the relays used on the power trim/tilt motors. I have twin Yamaha 85's on my boat and on of those relays went bad (engine started to go up by itself) so I removed it and I could still raise and lower the engine without the relay with the individual switch (the switch on the lever has never worked) What's the use of the relay in the system? Maybe for when you use the switch that tilts up and down both engines at the same time?? There was one relay for trimming up and one for trimming down. Both power trim up connected to one of them and both power trim down connected to the other one.
The relays were inline with the wiring harness in between the harness and the trim switches. Here are some pics of the relays:
Thanks for the help.
