got a 1999 130 hp yamaha been running fine for 11 years no probs took it out the other week fired it up idled for bout 5 mins then died wouldnt start at all .
found the tank had water in it replaced filter cleaned all lines from the tank to carby, filter , fuel pump, pulled carbs of and cleaned the whole lot out jets and all fires up then dies, if you play with accel and choke while starting can get to run at higher speeds then dies
seems if you spray carby clean down air filter picks up then drops off .
also if you take leads off 1 by 1 while running top 2 die then pick up bottom left the same but bottom right nothing .
just wondering if its pasts the carbs the whole lines where full of water and sludge any help would be great thnx.
